Importing Geometry (from Solidworks)
I have a model made in solid works, when I save it (.IGS) and import it one segment is imported as a solid while the other segments appear as surfaces, how do i get them all to import as surfaces?
Screenshot showing problem
    edited March 2019
    You can select a face on the solid body, use Copy and Paste and you will have a surface as well as the solid. When you have done this for each face of the solid, you can delete the solid.
    edited March 2019
    select all necessary surfaces. then use ctrl + c and ctrl + v to copy these faces.
    once you copy necessary faces, you can delete original one. if some faces are missing, you can create those in spaceclaim.
