SpaceClaim Does Not Recognise Parameters After Reopening
adamkovacs12adamkovacs12 Member Posts: 2
Hi everyone,
I am using the 18.1 version of ANSYS Workbench and I am trying to set up a parametric study. For this, I create the necessary parameter in SpaceClaim and call it in a script to make the necessary changes in geometry as it can be seen on the following picture:
However, after closing SpaceClaim and opening the geometry again, when I try to run the given script I get the following error as it could not see Parameter1 anymore:
If I create a new Parameter in this session, it can see only that one:
Does anyone have an idea what can be the problem and how it could be avoided? I had no issue with this on 19.1 Student but I need to use the university computers for my project and it only has this version...
Thank you very much for the help in advance,
Kind regards,
Adam
EDIT: I realised the error message cannot really be seen, it says:
" Parameters instance has no attribute 'Parameter1' "
