Unknown Error
Hi, I've been coming across a weird issue using the CFX solver and I was hoping someone here could help me. I've done substantial research on this already in an attempt to fix it but so far have been unsuccessful. Below is the details of the error.
 Details of error:-
 Error detected by routine MAKDAT
 Illegal data area length CDANAM =  NCOMPT CDTYPE =  INTR ISIZE =  0
 CRESLT = SIZE
 Current Directory : /INTERP/SOLUTION/DST/VX
 |                   ****** PROBLEM REPORT ******                     |
 | Subsystem: Input and Output                                        |
 | Subroutine name: ErrAction                                         |
 | Severity level: Fatal Error                                        |
 | Error message number: 001100279                                    |
 | Message:                                                           |
 | Stopped in routine MEMERR                                          |
 |                An error has occurred in cfx5solve:                 |
 | Error interpolating results onto the new mesh: C:\Program          |
 | Files\ANSYS                                                        |
 | Inc\v191\CFX\bin\winnt-amd64\double-int64\solver-mpi.exe exited    |
 | with return code 1.                                                |
Other online sources I've checked have suggested increasing the interpolator memory factor and catalog size, along with the other factors in the interpolator tab of the solver, but so far nothing. I was also recommended to try setting the memory factors to zero on account of this line "Illegal data area length CDANAM =  NCOMPT CDTYPE =  INTR ISIZE =  0" also with no success. Any ideas? I am running this from a PC with very high specifications so there shouldn't be an error with memory limits.
