K-w SST y+ range
Hello, I am relatively new to CFD. I am modeling the flow inside a converging diverging nozzle with pressure inlet and pressure outlet BCs in ANSYS Fluent. I read up online that using K-w SST turbulence model is best suited for finding flow separation in the nozzle. I also am relatively new to meshing and read up that I need to use boundary layer mesh on the walls of the nozzle to capture the boundary layer phenomena. I also read up that finding the y+ value will dictate whether the first layer thickness of the boundary layer mesh is correct or not. I need to know what the range of y+ is for the k-w SST model in Fluent with Low Reynolds correction turned off.
