Missing Analysis Systems from toolbox — Ansys Learning Forum
I have downloaded and install ansys 18.1 student version and when I opened ansys workbench the analysis systems was missing from the toolbox.i have also checked the toolbox customization but analysis systems is not there.
«1
  • peteroznewmanpeteroznewman Member Posts: 11,369
    edited December 2017
    Did this computer have any previous versions of ANSYS installed?  If so, previous versions have to be uninstalled and all traces removed. Here is a guide.
    I recommend you uninstall 18.1 and download and install 18.2 which is the currently available Student version.
  • Raef.KobeissiRaef.Kobeissi United KingdomMember Posts: 443
    Sometimes after installation Workbench may requires to be opened a second time before you see the systems appear and as Peter said make sure that you have no remaining files from other ANSYS versions on your Computer.
    Cheers
  • pglpgl Portland, Oregon, USAMember Posts: 405
    edited January 2018
  • Arthur VMArthur VM Member Posts: 1
    edited July 2018
    I just installed Ansys 19.1 student version and I have the exact same problem. I've tried opening the workbench a couple of times and restarting the computer. I've also tried 'reset windows layout' and 'view all/ customize'. The analysis systems remains missing.
    Does anyone have a suggestion? Thanks in advance
    Arthur
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Forum Coordinator Posts: 3,071
    edited July 2018
    Hi Arthur,
    Try this, open up Windows Explorer and paste the following into the address bar
    %appdata%\ansys\
    Once on this page, rename the v191 folder to anything else (such as v191.old)
    If that doesn't help, check this
    open up CMD Prompt, then issue the following command (this is for default installation path, if you've installed it in a non-default path, you have to change the path accordingly)
    "C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\winx64\ansysli_util" -checkout aa_t_i
    If your licensing is fine, you should see the output like
    "..... INFO Demo license file  C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.
    aa_t_i OUT ....."
    Thank you,
    Win
  • KiranKiran Member Posts: 1
    edited December 2018
    Hello tiriaks,
    Thank you for suggestion of changing the name of the folder v191. It really worked.
    I was trying to find solution the problem like here of missing analysis system toolbox. Finally it worked today.
    Thank you all for your help.
    Best regards
    kiran
    Hi Kiran,
    Sounds good. Thank you for the update. Glad it works for you.
    Win
  • ChinyereChinyere Member Posts: 7
    edited February 2019
    Hello tiriaks,
    I just installed Ansys 19.2 student version and I have the exact same problem.i haven't had any previous version installed. I've tried opening the workbench a couple of times and restarting the computer. I've also tried 'reset windows layout' and 'view all/ customize'. The analysis systems remains missing.
    I checked using the CMD step and my licensing is fine.
    I tried renaming the v192 folder and a new v192 is created after I open Ansys and the analysis system tab is still missing.
    Thanks for a solution in advance.
    Chinyere
    Hi Chinyere,
    Thanks for the information and trying those steps to rule out licensing issue.
    Please create a new thread on this and we can work on your issue on there (please reference this thread).
    Please post the output of the
    set
    command in the CMD Prompt
    Win
  • SaurabhDSaurabhD Member Posts: 17
    edited March 2019
    I'm facing the same issue as that of Chinyere. Can some one help to resolve it. I've renamed the folder and also have also checked the CMD step.
    Thank you in advance
    edited March 2019
    Hi SaurabhD,
    Please create a new thread for your issue and include output of the 'set' command.
    Win
  • Baswa17Baswa17 Member Posts: 3
    edited June 2020
    Sir itried this method and my command prompt shows this
    ANSYS LICENSE MANAGER ERROR : Request name aa_t_i does not exist in the licensing pool.
    Feature has expired.
    Feature:       aa_t_i
    Expire date:   31-jan-2020
    License path:  C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic;
    FlexNet Licensing error:-10,32
    For further information, refer to the FlexNet Licensing documentation,
    available at "www.flexerasoftware.com".
    aa_t_i CHECKOUT FAILED
  • Antonio_ALK26Antonio_ALK26 Member Posts: 1
    Someone like fixing this problem, already install it again and it's still the same
  • RobRob UKForum Coordinator Posts: 8,851
    Which version is that (release number and whether it's Student, Teaching or Research).
  • DrAmineDrAmine GermanyForum Coordinator Posts: 6,847
    @sagarpatil925 and @Antonio_ALK26 are you both able to launch any product Standalone like Fluent?
  • sagarpatil925sagarpatil925 Member Posts: 4
    @DrAmine
    This message is been displayed in Console window when tried to launch Fluent
    2021/03/22 21:56:27 INFO Demo license file C:\PROGRA~1\ANSYSI~1\ANSYSS~1\Shared Files\Licensing\student.lic exists.
    ANSYS LICENSE MANAGER ERROR:Capability Fluent Meshing does not exist in the ANSYS licensing pool.
    None of the products enabling this capability are available in the specified license path:
    ANSYSLI_SERVERS:
    FLEXlm Servers: C:\PROGRA~1\ANSYSI~1\ANSYSS~1\Shared Files\Licensing\student.lic
    Hit return to exit.
    Unexpected license problem; exiting.
    @mmadore
    C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\ansyslmd.ini
    the above file doesn't exist.
    CMD Prompt "Set" Command out put was as follows
    C:\WINDOWS\system32>set
    ALLUSERSPROFILE=C:\ProgramData
    ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
    ANSYSLI_ELASTIC=1
    ANSYSLI_LCP=1
    ANSYS_SYSDIR=winx64
    ANS_OLD_ATTACH=1
    APPDATA=C:\Users\Sagar\AppData\Roaming
    AWP_LOCALE202=en-us
    AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
    CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=LAPTOP-KRJ8U3MC
    ComSpec=C:\WINDOWS\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    GOOGLE_API_KEY=no
    GOOGLE_DEFAULT_CLIENT_ID=no
    GOOGLE_DEFAULT_CLIENT_SECRET=no
    HOMEDRIVE=C:
    HOMEPATH=\Users\Sagar
    LOCALAPPDATA=C:\Users\Sagar\AppData\Local
    LOGONSERVER=\\LAPTOP-KRJ8U3MC
    LSTC_LICENSE=ANSYS
    NUMBER_OF_PROCESSORS=8
    OneDrive=C:\Users\Sagar\OneDrive
    OneDriveConsumer=C:\Users\Sagar\OneDrive
    OS=Windows_NT
    Path=C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\WINDOWS\System32\OpenSSH\;C:\Users\Sagar\AppData\Local\Microsoft\WindowsApps
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 142 Stepping 10, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=8e0a
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
    SystemDrive=C:
    SystemRoot=C:\WINDOWS
    TEMP=C:\Users\Sagar\AppData\Local\Temp
    TMP=C:\Users\Sagar\AppData\Local\Temp
    USERDOMAIN=LAPTOP-KRJ8U3MC
    USERDOMAIN_ROAMINGPROFILE=LAPTOP-KRJ8U3MC
    USERNAME=Sagar
    USERPROFILE=C:\Users\Sagar
    windir=C:\WINDOWS
  • mmadoremmadore Ansys Employee Posts: 823
    @sagarpatil925 Please set these variables to 0, not 1, or entirely remove them.
    ANSYSLI_ELASTIC=1
    ANSYSLI_LCP=1
    @mmadore
    From where Can i remove this value
    ANSYSLI_ELASTIC=1
    ANSYSLI_LCP=1
    For guidance on creating an Environment Variable please refer to this link. You need to create a NEW Variable.
    https://www.onmsft.com/how-to/how-to-set-an-environment-variable-in-windows-10
