Mesh not appearing in Fluent
I am using Fluid flow Fluent but the mesh does not appear, there is nothing shown in the window. This problem only happens with Fluent and in one computer, as I opened the same file on another computer and the mesh appeared. It also happens with all meshes of Fluent files, not just with one file.
On the other hand, sometimes there is the following message: "Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface."
I can modify everything but without seeing the mesh in the window.
How can I fix it? Thank you in advance for your help!
    edited April 2019
    go to task page - display or setting up domain tab - display
    select outline and click display
    this will display your mesh.
  • rebecazafrarebecazafra Member
    edited April 2019
    I have done what you said but I still can not see the mesh. It does not work.
    Do you perhaps have another solution?
    Thank you!
  • KremellaKremella Admin
    edited April 2019
    I've moved your question the Installation and Licensing section for better visibility. I hope this helps.
    Best,
    edited April 2019
    Hi rebecazafra,
    This is likely a graphics issue.
    Open CMD Prompt, then type the following command
    dxdiag
    then post the screenshot of the 1 page and the 'Display' page here.
    Also, open up 'Device Manager' -> expand the 'Display adapters' and post the screenshot of it.
    Win
    edited April 2019
     Hello tsiriaks,
    See the screenshots below. Many thanks!
    edited April 2019
    Hi rebecazafra ,
    Thank you for the info.
    Please try this
    right-click on the desktop > Nvidia Control Panel > Manage 3D settings > Under "Preferred graphics processor" , change from "Auto-Select" to "High-performance NVIDIA processor , then click "APPLY" in the bottom right.
    Win
    edited April 2019
    Hello again tsiriaks,
    It worked and now I see the mesh. Thank you very much for your help!
    edited April 2019
    Hi rebecazafra,
    Perfect ! Thank you for the update.
    Please mark this thread as resolved ('Is Solution') , so we know there is a resolution for it.
    Win
  • cnokekecnokeke Member
    edited April 2019
    I'd like to know how to reduce the number of cells to 512,000 so that my geometry can appear in fluent.
  • jcalleryjcallery Forum Coordinator
    edited April 2019
    Hi cnokeke,
    Could you please create a new thread for that question in the appropriate physics section?
    Thank you,
    Jake
  • JulianMarsanoJulianMarsano Member
    edited May 21
    I have the same problem as rebecazafra said but I have an Intel UHD 620 so I can't do that. Do you know what's my problem?
    edited May 21
    JulianMarsano, you can try updating graphics driver to the latest version available.
    If that doesn't help, please create a new thread for your own issue. You can add the link to refer to this thread if you like.
    edited May 21
    You're a genius! Saved my life... Thank you so so much.
    Now I only have one last question, how did you know that may be the problem? I've tried absolutely everything and I didn't come up to a solution...
    edited May 22
    Thank you. Glad that works for you.
    The issue is related to graphics. Generally, it is recommended to use the graphics cards that have been tested and with latest driver installed. In your case, we can't do anything with the graphics card part, so the only thing you can try is updating graphics driver. This however doesn't guarantee to help all the time because the machine is not using tested graphics card.
