LICENSE SERVER ERROR AND NOT ABLE TO INSTALL ANSYS 2019R1
I am a student, I currently installed ANSYS 2019 r1 academic student version and after installation, I am having a problem starting it. Here are few pics of it. Can anyone help me out?
Thanks in advance.
This is pic of mechanical apdl.
This is pic of workbench.
Hi nikhil12345,
Could you please open a command prompt, and type:
set
and post a screenshot of the result?
Thank you,
Jake
Thanks for reply jake
here is the pic
Hi nikhil12345, it doesn't look like all of it was included in the pic.
Please try this instead:
set | clip
That will put the output in your clipboard.
Then paste it into the post here.
Thank you,
Jake
Thanks for the reply
Sir I am not able to find it.
Can you help me out?
Start -> type cmd -> Click on "Command Prompt"
At the prompt type:
set | clip
Then open a new / blank notepad document, and right click in the white area and select paste.
Then copy and paste that into a post here in this thread.
Thank you,
Jake
Also please try the suggestions in the following posts:
https://studentcommunity.ansys.com/thread/installation-issue-3/?order=all#comment-d318865d-49ea-4c10-aa7b-a9de0134cbd3
https://studentcommunity.ansys.com/thread/error-when-installation-and-launching-workbench-19-2-student/?order=all#comment-ad9a61fa-7ca1-44de-96b3-a9d300189131
Thank you,
Jake
I tried first one, I got
I did not get what to do after renaming .ansys
Thanks for the reply.
These are the pics of set | clip from cmd
Thanks for reply.
Sorry for the inconvenience I was not able to add the file.
This is a detailed pic,
Please open windows file explorer.
in the address/path bar type:
%APPDATA%
That will take you to a folder, and inside that folder you should see an ansys folder.
Please right click on the ansys folder and select "Rename"
then rename that folder to ansys_old
Then try your application again.
Thank you,
Jake
Sir, I tried the above step, but the result was the same
Hello there, Can you please suggest how to get Ansys working?
I am not able to use it.
Hi nikhil12345,
If you open a DOS CMD Prompt and type in the following, What is the output?
ping localhost
Thank You,
Geo
Also, I see there is a space in the username.
Can you try creating a local user on this machine without a space in the name.
That has been seen to cause issues.
Thank You,
Geo
Sir, Thanks for the reply,
Here is the pic of ping localhost.
Sir, I don't know to change the local user name and if I change it will it work? As I am getting local server error or could not connect to the license server.
Can you specify the reason? This was one or two weeks back, I had version 19.2 which got the same error so I uninstalled it and installed it again it got the same error so now I installed this new version. And it shows the same error. So can you please help me out. And now I again installed it, should I set an environment variable for license and should I install the license manager and license server.
The new error is that could not connect to any license server and could not connect to local host,.jpg?width=690&upscale=false)
Thank you
Hello sir, I found this while searching servers and other stuff,
which reads as,
-------------------------------------------- NORMAL STARTUP 2019/04/29 22:51:22 ---------------------------------------------
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64. Updated at ANSYS Release 2019 R1. Started on 2019/04/29 22:51:22 by NEHA [email protected]:winx64 with pid 8212.
(C) 2007 - 2019 ANSYS, Inc. Unauthorized use, distribution, or duplication is prohibited.
Built Using FlexNet Publisher v11.13.1.4 build 179569 x64_n6
Built Using OpenSSL 1.1.0i 14 Aug 2018
Please note that entries in this debug log have the following format:
TIMESTAMP ACTION FEATURE REVISION (BUILD DATE) A/B/C/D W/X/Y/Z PID:MPID:APP:[email protected]
LATFORM
ISPLAY SOCKET:IP
Licenses statistics:
A is the number of licenses requested by this ACTION.
B is the number of licenses used by this USER.
C is the number of licenses used by all users.
D is the number of licenses available in the local license pool.
License server performance statistics:
W is the number of currently connected client applications.
X is the maximum number of connected client applications.
Y is the unique serial number of this client application.
Z is the number of all client applications served by this Licensing Interconnect server.
2019/04/29 22:51:22 INFO ANSYSLI_CMD=C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\winx64\ansysli_client.exe -nodaemon -demo -log C:\Users\NEHAA~1\AppData\Local\Temp\.ansys\demo.log
2019/04/29 22:51:22 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 22:51:22 INFO ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2019/04/29 22:51:24 INFO ANSYSLI_DEMO_PORT=49699
2019/04/29 22:51:24 INFO ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 22:53:20 INFO Ready to accept connections.
2019/04/29 22:53:21 HANDSHAKE_ERROR 1/1/1/1 65488:127.0.0.1
System error: 10053 "An established connection was aborted by the software in your host machine.
2019/04/29 22:53
6 INFO License server shutdown is complete. Thank you.
-------------------------------------------- NORMAL STARTUP 2019/04/29 22:53:52 ---------------------------------------------
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64. Updated at ANSYS Release 2019 R1. Started on 2019/04/29 22:53:52 by NEHA [email protected]:winx64 with pid 9860.
LATFORM
ISPLAY SOCKET:IP
2019/04/29 22:53:52 INFO ANSYSLI_CMD=C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\winx64\ansysli_client.exe -nodaemon -demo -log C:\Users\NEHAA~1\AppData\Local\Temp\.ansys\demo.log
2019/04/29 22:53:52 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 22:53:52 INFO ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2019/04/29 22:53:55 INFO ANSYSLI_DEMO_PORT=49704
2019/04/29 22:53:55 INFO ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 22:55:50 INFO Ready to accept connections.
2019/04/29 22:55:50 HANDSHAKE_ERROR 1/1/1/1 65488:127.0.0.1
2019/04/29 22:56:09 INFO License server shutdown is complete. Thank you.
-------------------------------------------- NORMAL STARTUP 2019/04/29 23:21:09 ---------------------------------------------
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64. Updated at ANSYS Release 2019 R1. Started on 2019/04/29 23:21:09 by NEHA [email protected]:winx64 with pid 10568.
LATFORM
ISPLAY SOCKET:IP
2019/04/29 23:21:09 INFO ANSYSLI_CMD=C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\winx64\ansysli_client.exe -nodaemon -demo -log C:\Users\NEHAA~1\AppData\Local\Temp\.ansys\demo.log
2019/04/29 23:21:09 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 23:21:09 INFO ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2019/04/29 23:21:11 INFO ANSYSLI_DEMO_PORT=55719
2019/04/29 23:21:11 INFO ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 23:23:15 INFO Ready to accept connections.
2019/04/29 23:23:15 HANDSHAKE_ERROR 1/1/1/1 65488:127.0.0.1
2019/04/29 23:23
0 INFO License server shutdown is complete. Thank you.
-------------------------------------------- NORMAL STARTUP 2019/04/29 23:24:07 ---------------------------------------------
ANSYS Licensing Interconnect version 1.9.7 (20181112) for winx64. Updated at ANSYS Release 2019 R1. Started on 2019/04/29 23:24:07 by NEHA [email protected]:winx64 with pid 7668.
LATFORM
ISPLAY SOCKET:IP
2019/04/29 23:24:07 INFO ANSYSLI_CMD=C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\winx64\ansysli_client.exe -nodaemon -demo -log C:\Users\NEHAA~1\AppData\Local\Temp\.ansys\demo.log
2019/04/29 23:24:07 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2019/04/29 23:24:07 INFO ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\Licensing\prodord\ansysli.prodord.xml'
2019/04/29 23:24:09 INFO ANSYSLI_DEMO_PORT=58710
2019/04/29 23:24:09 INFO ANSYSLI_CLIENT_IDLE_TIMEOUT=10
2019/04/29 23:26:07 INFO Ready to accept connections.
2019/04/29 23:26:07 HANDSHAKE_ERROR 1/1/1/1 65788:127.0.0.1
2019/04/29 23:26:21 INFO License server shutdown is complete.
This might help you solve the problem and sorry for troubling you guys.
Sir I found this inC:\Users\NEHA A\AppData\Local\Temp\.ansys while searching for servers and other results for solutons.jpg?width=690&upscale=false)
Which reads as,
LATFORM
ISPLAY SOCKET:IP
2019/04/29 22:53
LATFORM
ISPLAY SOCKET:IP
LATFORM
ISPLAY SOCKET:IP
2019/04/29 23:23
LATFORM
ISPLAY SOCKET:IP
2019/04/29 23:26:21 INFO License server shutdown is complete. Thank you.
This might help you solve the problem and assist me to use the Ansys version back into working condition.
Please see the steps here and create a second Windows user account that does not have space or special characters in the name (your current one has space in it)
https://www.webucator.com/how-to/how-create-second-user-account-windows-10.cfm
Win
Hello Sir, Thanks for reply.
I created new account as per the instructions but still I am getting same error.
What am I supposed to do.
This new account created is local account.
Thank you
Hello Nikhil12345,
Can you make sure the following line in in your C:\Windows\System32\drivers\etc\hosts file:
127.0.0.1 localhost
If not in there, please add it and try opening a DOS CMD window and
ping localhost
Does it return:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
If so, now try to run.
Thank You,
Geo
