Causes of zero values in post processing?
Having applied loads as line pressures and solved the model ANSYS returns the "Solution is done" message. When I view the outputs in general post processing - looking at displacements, reactions and stresses - all values are 0. Is there an error I am making for the load (1430N/m2) to not be recognised? Or is it another error I am making?
Matt
    edited April 2019
    Matt, do you have Beams?  You have to use the Beam Tool to look at stress in the beam.
  • Matt17Matt17 Member
    edited April 2019
    Hi Peter,
    I've assigned my beams as RHS 120x90mm. There are 50+ with pressures of 1.43kN/m2. They carry the line load to a central keel section which is a shell element (I'm trying to design a keel for a ship display).
    I think I may be missing something in how the beams which sit on top of the keel transfer their loads to the keel section below them. So far as I can see the geometry is ok. I have attached a screenshot to try to explain myself better. The keel is supported under the keel where a rib is located for now.
    Thanks.
    edited May 2019
    Not knowing much about Mech, but having a good understanding of how boats are built....
    edited May 2019
    How have you defined the contact between the ribs & keel? If you check the position (and gravity) can the stringers hold the ribs in such a way that they don't actually touch the keel?
    edited May 2019
    The error was regarding my loading as a pressure on a line rather than a load on a beam. I'm now getting results. Thanks for all the advice and comments.
