Heat transfer through boiler walls
TamoorTamoor Member
Hi
I am simulating combustion inside boiler using Fluent. I have  a question regarding heat transfer through walls. I want to remove certain amount of heat from the walls (13MW) but I have problem using boundary conditions. I tried to use negative heat flux but then wall temperature becomes negative or too low and temperature profile has a strong gradient near walls. I want to remove fixed amount of heat and heat flux is not working. If anyone has an idea how to handle this problem please let me know
  • veeraveera Member
    edited May 2019
    did u assigned material property clearly?
  • TamoorTamoor Member
    edited May 2019
    The entire domain is fluid domain, however, I have assigned walls as aluminium in boundary conditions with small thickness
    edited May 2019
    Are the walls internal walls? Can you insert the screenshot of the geometry, the cell zones and the wall boundary condition?
    edited May 2019
    Have you tried giving the wall a finite thickness and using a negative heat generation rate?
    edited May 2019
       Thank you for your reply Amine, I modelled only the fluid domain with no separate walls, I have attached snapshots of geometry (inlet is at bottom, outlet at top, one side is symmetry and three walls from which heat is to be removed). Also attached you will find cell zone and boundary conditions. Your help is highly appreciated.
    Kind regards,
    Tamoor
    edited May 2019
    Yes, I tried using negative heat generation but it's not working. Sorry I couldn't attach pictures due to some error. But you can find geometry picture attached to original post. I have only one zone (which is fluid with methane-air 2 step mixture) and at walls I have tried heat flux and negative heat generation rate as well but they don't work
    edited May 2019
    I do not download attachments. Please try insert intsead of attaching.
    edited May 2019
    I cannot insert picture, I am getting an error
    edited May 2019
    If this is an external wall it is just safe to provide a negative heat flux. Have you tried that?
    edited May 2019
    I haven't tried that. Actually, I only modeled fluid domain with internal walls, but I think I can try modelling external wall and then specify the negative heat flux. Thanks for helping I'll try that and will let you know.
    Kind regards,
    Tamoor
    edited May 2019
     With internal walls what you are removing from one side will be added to the other side and so back to fluid. Use external walls
