Surface Heat Transfer Coefficient in Fluent
SFatihKSFatihK ?zmir / TurkeyMember
Hi to all,
I am working on a project that is related to conjugate heat transfer and I have to make the unsteady analysis. Since unsteady analysis would take a lot of time, I did a steady analysis of liquid and solid geometry. I exported the surface heat transfer coefficients from steady analysis as a  profile. I wanted to see the same result from the conjugate heat transfer analysis in a short time by defining the HTC profile ( related to liquid ) to the relevant walls only to the solid part. But the HTC profile heated the solid part. It would be cooled. What's wrong with the HTC profile from Fluent or what I'm doing wrong?
I'm new in the community.
