Extracting the Current value from a node in Electrical Simulation
I am using the Electrical simulation module for a few simulations and I need to extract the voltage and current at particular nodes in the postprocessing using APDL commands. As per the ANSYS APDL documentation, the following codes should work for Voltage extraction and Current extraction
*GET,ParameterName,NODE,N,VOLT    => Gives the voltage at the node 'N'. This works fine
*GET,ParameterName,NODE,N,CURR   => Should give the current at the node 'N'. This doesnt work for some reason.
Does anyone have any lead on how I can extract the Current value at a particular node like I can extract the Voltage ?
