Is it possible to create journal backwards from used functions?
duraldural Member Posts: 1
Hi everyone, my question is already whole said in the topic title. Is it somehow possible to create journal file backwards from used functions? I mean, like suppose I have set everything and I am ready to run calculations. However, I have to use the same boundary conditions/etc/etc more times. Are these functions saved somewhere? In some temporary folders or whatever.I am really curious..thanks!
edit: to be more precise, I have found this, but I am not sure if its also working when it is not workbench ( I dont have ansys near me for few days)
Record Journal File: Specify if a journal file should be recorded. If this check box is selected, ANSYS Workbench writes a journal file (.wbjn) for each ANSYS Workbench session and the following options are enabled:
  • Journal File Directory: Select the directory to which journal files should be written.
    On Windows, the directory preference defaults to %TEMP%\WorkbenchJournals.
    On Linux, the directory preference defaults to the following, in order:
    1. $TEMP/WorkbenchJournals
    2. $TMP/WorkbenchJournals
    3. $HOME/.ansys/WorkbenchJournals
    If you record a session (File> Scripting> Record Journal) for future playback, the same information is written to both the location specified here and to the file specified when you begin recording.
