Failed Mesh
AsarAJAsarAJ DenmarkMember
I have been trying to Mesh my model for a long time, and I cannot figure out how to do it successfully.
If anyone has any suggestions it would be great!
Thank you for stopping by
  • jj77jj77 Member
    edited May 2019
    If you upload your model (.wbpz file, to create archive, use file/archive), by using the attach button next to your post, then someone might be able to have a look
  • AsarAJAsarAJ DenmarkMember
    edited May 2019
  • jj77jj77 Member
    edited May 2019
    This model should be modelled with shell elements not 3D solids (some parts are 5 mm thick, and you need to have at least 2-4 elements trough the thickness so you will end up with millions of elements), so you need to represent all 3D parts with equivalent surfaces (that will later have a shell thickness).
    edited May 2019
    I have tried to make into shells, still no mesh could be generated.
    I attach the new model. I don't understand what is the problem.
    it would be great if you can take a look.
    Thank you very much!
