Problem to run CFX solver with user fortran in parallel mode
Hí guys,
I have a problem when I use routines in FORTRAN in parallel mode. In serial mode there are no problems, but in parallel the error with code 30 appears. I put a copy of the cfx5mkext.ccl file with the correct architecture and the solver-mpi.lib line in the working directory and there is still the problem. Has anyone had this and solved it? I'm probably making a mistake in handling the cfx5mkext.ccl file. Thank you very much.
