Force Probe through Time - Parametric
in Structures
Hello, I'm running a simple analysis on a fracturing Beam using the VCCT method. I'm doing this using parameters, basically changing some geometry values and some material data. I want to get, for each simulation, a force vs displacement diagram, or at least the force through time. So far I've only been able to get the Max force, but I'd like to get the whole set of results. Is that possible?
Thank you very much
Xavi
