How to uninstall ANSYS license manager
After uninstalling the ANSYS programs from the computer, I am still not able to delete the ANSYS Inc. folder from Program Files-- My Computer .
I want to completely remove the ANSYS files from my device.
    edited June 2019
    open up elevated CMD Prompt , right-click on CMD Prompt and 'run as administrator' , then issue the following commands. Make sure you change your install path accordingly
    "C:\Program Files\Ansys Inc\Shared Files\Licensing\winx64\ansysli_server" -k stop
    "C:\Program Files\Ansys Inc\Shared Files\Licensing\winx64\ansysli_server" -k uninstall
    sc stop ANSYSLicensingTomcat
    sc delete ANSYSLicensingTomcat
    then, you should be able to delete the ANSYS Inc folder.
  • AntangAntang United StatesMember
    edited August 2019
    I'm not too familar with the command prompt but how do i do this if my first line of the prompt is "C:\>" and my ansys is in that exact same folder destination.  Also do I need to write that with the quotations?
    edited August 2019
    Please post the screenshots of your ANSYS directory.
    It's ok if your first line has C:\>
    Yes, you need to include quotes
    edited August 2019
    Nevermind I think i got it thanks!
    edited August 2019
    sounds good.
    Win
  • I need to remove license folder but the CMD prompt shows above address...i.e..C:\windows\system 32.......while license folder location is C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64 ....how to change as it can not recognize the address
    No need to change directory. What I provided is called 'absolute path' You just need to include the quote.
    Note: When we changed the platform to this new one, the backslash is not transferred to this new platform correctly. The commands are
