ANSYS 17.2 License not Available for Coupled Solver
Hey everyone,
I'm attempting to run a coupled fluid-structure analysis with ANSYS Workbench 17.2. I have licenses individually for Fluent and Mechanical, but even though the Fluent and Transient Structural runs work fine on their own, when coupled using the process described here (Part 1: ; Part 2: they error out as shown:
 |                 System Coupling Co-Simulation Summary              |
  Participant : Mechanical APDL (Solution 1)
   Version/Build Info    = Mechanical APDL Release 17.2     UP20160718
                             DISTRIBUTED WINDOWS x64  Version
 Participant : Solution
   Version/Build Info    = ANSYS Fluent 17.2.0, Build Time:Jul 27 2016
                           11
9:44, Build Id:10113, OS Version:win64
 |                              NOTICE                                |
 | An exception has occurred and has been transmitted to the coupling |
 | participants.  These participants have been disconnected from the  |
 | coupling service.                                                  |
 |                      System Coupling Exception                     |
 | Origin            : Airflow (Solution)                             |
 | Error Code        : 2                                              |
 | Error Description :                                                |
 |   Fluent encountered fatal error after sync point Analysis         |
 |   Initialization: CFD Solver license [ANSYS Academic Research      |
 |   Mechanical and CFD] is not available for coupled run             |
 System coupling run completed with errors.
Attached is an image of the runtime errors we get during the co-simulation process.
It seems that there's an additional coupled-simulation license required for this type of co-simulation? If so, does anyone know how we can obtain this license?
Thanks a lot
