Can't create discussion
I get the following error when I attempt to create a discussion in any other section:
Access Denied
You don't have permission to access "http://studentcommunity.ansys.com/topic/create/" on this server.
Reference #18.cdfc0a17.1561245718.f897c6b
    edited June 2019
    And weirdly this didn't show up until today.  Try clearing the browser cache and/or use a different one, that seems to fix most problems. From checking there's nothing in the moderation list and no flags against your ID.
    Edit: I've even had to approve my own post! Is the site still blocking you?
  • RaphaelRaphael Member
    edited June 2019
    Still not working. I tried clearing the cache and Google Chrome (I was originally on Pale Moon, a Firefox variant). Nothing worked. All of this was today after your reply.
    If you had to approve your own post then I assume it's not just me.
    edited June 2019
    I needed to approve your last post. Sometimes this is required...
    edited June 2019
    However my inability to create discussions in other sections remains. Is there something that can be done about this?
    Alternatively, maybe I could post the intended text here or send it in a message and someone could post it in the appropriate forum on my behalf?
    Or could I post it as a discussion here and a mod/admin could move it to the appropriate section?
    edited June 2019
    You can try that. I'll flag your ID internally to see if there's a problem with it.
  • joaoalvesjoaoalves Member
    edited April 2020
    Sorry, an error occurred while processing your request.
    does anyone know why?
    edited April 2020
    If you're posting a long message break it up, and if you're using ( )  switch to [ ] as there's some syntax that causes problems [do NOT ask why.....].
    edited April 2020
    No, the problem existed when I clicked start discussion but today it is already working! Thank you!
