Error while loading the DockingPane
Dear all,
    I have installed the ANSYS 2019R2 for both Centos 7 and Ubuntu recently. The installation succeeded but when I trying to open "Geometry" (DesignModular) under Workbench. Both of them (the Centos 7 and Ubuntu version) pops up an error message saying "Error while loading the DockingPane). I have ANSYS 19.0 installed for these systems previously, and they have NO problems. Also, ANSYS Fluent 2019R2 works in these systems too. Please help!
Alan
    edited June 2019
    Hi Alan,
    Are you physically using this machine or you use some kind of remote access tool to access it ?
    Also, try this: Close all ANSYS applications , then rename ~/.mw/Application Data/Ansys/  and  ~/.ansys/
    Win
  • AlanAlan Member
    edited June 2019
    Hi Win,
        Thank you for your reply.
         I physically use these machines.
         I tried to "mv ~/.mw/Application Data/Ansys/ ~/.mv/Application Data/Ansys_old/" and "mv ~/.ansys/ ~/.ansys_old/" for both machines. The issue is still there.
    Alan
    edited June 2019
    Hi Alan,
    Let's focus on CentOS 7.
    Did you install redhat-lsb ?
    Is there any .err files under (default) /ansys_inc  ?
    Please post the screenshot of the error including the Workbench interface or surrounding areas.
    Win
  • AlanAlan Member
    edited June 2019
    Good afternoon Win,
        Installation of "redhat-lsb" resolved the problem in CentOS 7! Thanks!
        I tried to use the same trick for Ubuntu: "apt-get install lsb-core". Unfortunately, it does not resolve the problem. I found the /ansys_inc (for Ubuntu version) has an error file:  Install.err.tmp. Here is what it says:
    ###### Error #######
    Error executing configuration script '/usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigRSM.sh'
    '"/usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigRSM.sh"  -installdir "/usr/ansys_inc" -rev 194 -dotrev 2019 R2 -scripttosource "/usr/ansys_inc/v194/commonfiles/configs/linx64/config/ConfigCommon.tcl" -sourcedir "/tmp/ans_install_tmp4907" -os_lang en-us -install -skip_file_associations ' terminated after 1 attempts with the following error(s):
        Unknown error
    Exit Code: 0
    readlink: invalid option -- 'p'
    Try 'readlink --help' for more information.
    dirname: missing operand
    Try 'dirname --help' for more information.
    /usr/ansys_inc/v194/RSM/Config/tools/linux/rsmconfig: 26: /usr/ansys_inc/v194/RSM/Config/tools/linux/rsmconfig: /Framework/bin/Linux64/runwb2: not found/usr/ansys_inc/v194/aisol/.workbench: 1: /usr/ansys_inc/v194/aisol/../commonfiles/MainWin/linx64/mw/setup-mwuser: rpm: not found
    /usr/ansys_inc/v194/aisol/../commonfiles/MainWin/linx64/mw/setup-mwuser: line 151: rpm: command not found
    /usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /usr/ansys_inc/v194/aisol/dll/linx64/libans.common.clrhostmonou.so: unexpected operator
    /usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /usr/ansys_inc/v194/aisol/dll/linx64/libans.common.controlsu.so: unexpected operator
    /usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /usr/ansys_inc/v194/aisol/dll/linx64/libans.graphics.controlsu.so: unexpected operator
    /usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /usr/ansys_inc/v194/aisol/dll/linx64/libans.graphics.graphutilityu.so: unexpected operator
    /usr/ansys_inc/v194/commonfiles/configs/linx64/config/AnsConfigWB.sh: 170: [: /usr/ansys_inc/v194/aisol/dll/linx64/*ud.so: unexpected operator
    thanks,
    Alan
    edited June 2019
    Hi Alan,
    What about these two
    apt-get install libmotif-dev
    apt-get install lsb
    Win
  • AlanAlan Member
    edited June 2019
    Good morning Win,
         I tried these two commands. Both worked, but neither resolved the problem
    Alan
    edited June 2019
    Hi Alan,
    I think the root cause of that readlink error is similar to what Jake described in here
    https://studentcommunity.ansys.com/thread/installation-of-ansys-19-4-structures-2019-r2-on-kubuntu-19-4-freezes-at-arcnode/
    I would recommend to just stick with your CentOS.
    Win
  • AlanAlan Member
    edited June 2019
    OK. got it. Thanks!
  • Hello Win,
    I have the same problem
    ANSYS 2020R2 on
    SUSE 15 SLED SP1
    When starting ANSYS from shell, I get following error messages..
    /usr/ansys_inc/shared_files/licensing/linx64/ansysli_client: error while loading shared libraries: libldap-2.4.so.2: cannot open shared object file: No such file or directory
    Warning: Missing charsets in String to FontSet conversion
    Warning: Unable to load any usable fontset
    The workbench is starting, and I get the same error message
    Design modeler is opening and working , but the Docking Pane is missing
    I tried to install all packages with lsb and motif, but without success.
    Greetings,
    Holger
  • kaengokaengo Member
    edited November 12
    OK,
    I installed libldap,
    thereafter, I made a fresh install of ANSYS
    now, there is no error message when starting.
    But still, I get the ERROR WHILE LOADING THE DOCKINGPANE - error.
    Does anyone know, what to do??
    Greetings,
    kaengo
