ANSYS DISCOVERY AIM 19.2 Simulation
Hi i am new on using ANSYS DISCOVERY AIM 19.2 but i dont know if it will solve my problem or i need ANSYS FLUENT MODULE.
Problem: I need to analyse the air flow going through a solar collector and then exit a solar collector into a drying chamber where products need to be dried with that air. Essentially, into two stages. Stage 1: Atmospheric air (at certain humidity, pressure, velocity, temperature) enters a solar collector whose heat gain is via solar irradiation then Stage 2: air from solar collector enters a drying chamber to remove moisture from the products. Attached is an example of the solar dryer setup similar to what i intend to analyse
I am interested in evaluating the performance of the solar dryer (collector and drying chamber), fluid behavior within the solar dryer and around the product to be dried.
