Topology Optimization Validation Error
I've run a topology optimization of a part using the results from a modal analysis. When I try to bring the optimized model into spaceclaim by right clicking "Results" under the topology optimization system and selecting "Transfer to Design Validation System," I get the following error message:
"Unable to duplicate component /Schematic/Component:Results 15: Duplication command Mechanical.DuplicateResults failed: DuplicateResults->CreateDataObjects Failed. Unknown DataObject: Ansys.Simulation.Core.DataModel.ResultFileObj"
In the meantime I've validated the model by exporting the .stl, recreating a CAD file in NX, and redoing a modal analysis with the new model, but I'd like to know what's going wrong here regardless.
Thank you!
-Chris
