PPATH function includes the origin in every path defined
Hi all,
I have meshed a general block volume and I'm trying to use PATH along with ESEL to select elements in the neightbourhood (of radius "R") of a given element "i".
I use *DO to insert the X Y Z coords of a spherical path around " i " into PPATH,
then I issue ESEL,S,path,"MYPATH" to select elements, the expected result is a set of elements containing those around "i".
the problem is that, although the array of coordinates XYZ does not contain the value (0,0,0), the selected set of elements includes a "tail" of elements that goes from the origin to the element "i" as if the path defined by PPATH wasn't only a sphere of points but the sphere plus the origin, and that behavior holds for any element.
Code used:
/PREP7
*AFUN, DEG
!Dimensões do bloco
L = 0.1 ! Lado [m]
x1 = 0
y1 = 0
z1 = 0
x2 = L
y2 = L
z2 = L
 BLOCK, X1, X2, Y1, Y2, Z1, Z2
E _0= 2E11
Poiss = 0.3
ET, 1,SOLID185
MP, EX, 1, E_0
MP, PRXY, 1,Poiss
save
n_div = 30
ESIZE,,n_div
VMESH, 1,
i = 15879 ! "i-th" element
loc_ei_x = CENTRX(i)
loc_ei_y = CENTRY(i)
loc_ei_z = CENTRZ(i)
PATH, Viz, 70,30, 50
R_viz = (L/n_div)*(3**(1/2)) !Setting Neightbourhood radius
!Filling array of spherical coords phi and theta
ang_phi(1:21) = 0
*DO, i, 2,21,
ang_phi(i) = ang_phi(i-1) + 18
*ENDDO
ang_teta(1) = 0,120,240
!Creating arrays to store values of the x y z coords inserted into path for verification
*DIM,x_path, ARRAY, 21, 3
*DIM,y_path, ARRAY, 21, 3
*DIM,z_path, ARRAY, 21, 3
 !Inserting x y z into PPATH
k = 1
*DO, i, 1,21,
 *DO, j, 1,3,
x_path(i,j) =  loc_ei_x + R_viz*cos(ang_phi(i))*sin(ang_teta(j))
y_path(i,j) = loc_ei_y  + R_viz*sin(ang_phi(i))
z_path(i,j) = loc_ei_z  + R_viz*cos(ang_phi(i))*cos(ang_teta(j))
PPATH, k, , x_path(i,j), y_path(i,j), z_path(i,j)
k = k+1
 *ENDDO
*ENDDO
 ESEL, S, path, Viz,
Result:
