RSM failed to verify my credintials when connecting to the cluster
MohdElhashimiMohdElhashimi Oregon State UniversityMember Posts: 4
I've been trying to connect my machine to the cluster through the Ansys Remote Solve Manager (RSM). The HPC type is UGE(SGE).  I believe my configurations are all correct and I confirmed that with another research group that runs the same thing but it's just not working for me.
I checked the connection through the "telnet" command and it's working well. Also, my connection via MobaXterm is smooth. When I reached to the queues tab in the RSM configuration I get the attached error.
"System.InvalidOperationException: Timeout getting UseerProxy port for user ... [machine name] on submit-c..."
What might be the problem?
Thank you all.
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Forum Coordinator Posts: 3,071
    edited August 2019
    Check with your cluster admin to see if anything blocking ports. There are a lot of different ports being used. I think you can connect to RSM Launcher service port 91xx but you have issue connecting to ports used by User Proxy, which handles files transfer , etc. Ask your cluster admin to check file
    (default location) /ansys_inc/v1xx/RSM/Config/Ans.Rsm.AppSettings.config
    for these lines
    "PortRange" value=""
    "SocketTransfererPortRange" value=""
    by default these are blank, meaning it will always change ports. Your cluster admin can specify the ranges here and make sure the ports in these ranges are open. Please note to them to restart RSM Launcher service after modifying this file.
    Note: This should be done on the submission (head) node.
    Let us know how it goes.
    Win
  • MohdElhashimiMohdElhashimi Oregon State UniversityMember Posts: 4
    edited August 2019
    Thank you for the response. That looks like something that might affect all the cluster users. There are other groups running fluent simulations on the cluster without having my issue. So is that config. file shared among all the users ?
    edited August 2019
    That's what our cluster admin response:
    <add key="ProxyXmlRpcPortRange" value="50000-50100" />
         Default ports are usually greater than 50000.  This option may be required
            for environments where upper port range is restrictioned by firewall.  e.g. "1000-2000"
    and for the other line:
    <add key="SocketTransfererPortRange" value="" />
    Do you think the problem is the port we're using (9192) is way off that range?
    edited August 2019
    Thanks for the info.
    The 9192 is the fixed port used by RSM Launcher v19.2 service
    The issue you are having is with ports used by User Proxy. Unfortunately this is randomly assigned because it's a range of ports.
    the two main lines are
    If nothing is set, it will randomly use any port.
    Note: ProxyXmlRpcPortRange" value="50000-50100" is a different port range used by a different component of RSM. Not the user proxy that I was talking about.
    Win
  • lennartmlennartm Member Posts: 3
    Should these ports have different ranges?
    I have now set:
    <add key="PortRange" value="40000-59999" />
