Dynamic pressure higher than total pressure?
Any help would be hugely appreciated on this confusing issue.
I'm modelling an external supersonic flow of M=2 around an aircraft. The boundary conditions are a pressure far field.
Using the isentropic flow relations, for my altitude (18,300m) the static pressure is 7,158 Pa, which using the isentropic flow relations gives a total pressure as 56,008 pa. I input this as the gauge pressure in the far field boundary condition.
Operating pressure is set to zero.
I set the simulation to provide me with dynamic pressure as I need to calculate a drag coefficient, however upon viewing it in Post, the dynamic pressure in the far field is ~3x higher than the total pressure I input??
Is there something I'm missing here? I've gone over my setup over and over and it seems fine.
Thanks very much in advance.
Ed.
Hi Amine,
Thanks very much for posting an answer. from the ansyshelp.ansys.com website, which I accessed by clicking the help button in fluent, it says the following for high Mach numbers:
So I was under the impression this boundary condition was correct?
Please let me know any further thoughts on this.
Thanks again.
Ed
I do not understand your post sorry. Your input for Gauge Pressure is static pressure which you get from the isentropic relationship. For Ma=2, you need to get the stagnation pressure at that altitude (7158) and then you get the input for boundary (914 Pa round about)
