Rope Tension for heavy electric wire routing
Hello friends.
I am studying about force for heavy electric wire routing . As You can see, there are 3 pair torque power plant. and The left big one is just following the wire move. And the wire is about to move 300M, 500M, 700M. So i want get the force for routing heavy electric wire.
I use revolute to 7 cylinder and also set up transitional joint to the end of wire
I use displacement to the another end of wire and set up 200m moving.
and I was modeling the subject using ug nx. The mode is static structural using step time 10s but The model cannot be solved i dont know why. If there is someone who have idea, please help me please
