Ansys Mechanical APDL freezes by requesting any inforamtion from the Main Menu
I started working with Ansys Classic just some days ago. It worked fine and I already created some basic models.
Since this morning the programm freezes every time I request any kind of information from the main menu.
For example, I just defined three element types and I wanted to check them under Preprocessor>Element Type> Add/Edit/Delet. As soon as I try to open that list the program freezes and I can only close it through the Task manager.
I also saw, that a "cleanup-ansys-PCName-No." batch file is created. I'm not sure if that's normal or not, but I haven't noticed those files before the problem occured.
I restarted the PC, I uninstalled Ansys and installed it again but it's still the same problem.
Maybe I have to mention that windows requested a reboot this morning for some updates. Maybe that could be a reason?
I would be very happy to get some help with this!!
(I downloaded the student version 2019 R2.)
Thanks in advance
    edited September 2019
    If it worked earlier and stopped working all of a sudden, first thing you can try is to reset ANSYS configuration (These don't get deleted even if you uninstall ANSYS)
    You can do this by renaming C:\Users\<your_username>\AppData\Roaming\Ansys   folder to something else or you can launch CMD Prompt and issue the following command
    move %appdata%\ansys %appdata%\ansys.old
    Win
  • SilkeSilke Member
    Hello Win,
    thanks for your answer. I just used the command you suggested and it woked fine.
    But unfortunately it could not fix the problem. Any other ideas?
    Thnaks,
    Silke
  • SilkeSilke Member
    I just found out that submitting the job via APDL Product Launcher works fine.
    So it must be a problem with the Mechanical APDL interface or something like that.
    I've not seen a graphics issue with M-APDL GUI (since the GUI itself is pretty old and should not require much) but just for a kick, let's check graphics. What graphics card do you have on the machine and can you update its graphic driver to the latest according to the vendor website ?
    Win
  • wizard36wizard36 Member
    edited April 14
    This was happening to me too.  What I figured out was that I had moved from my desk with 3 monitors to my home office with 2.  When I had apdl open on the second monitor APDL was trying to open the pop-up boxes on a monitor that wasn't attached.  So it looked like it was frozen but in fact, it was just waiting for me to use the pop-up box that was open on a virtual monitor I couldn't see.  Once I moved the apdl to my laptop monitor it worked fine; opening the menu windows on the same monitor.
    edited April 15
    Thank you for sharing your resolution wizard36
  • Thank you wizard36. I scratched my head out trying to figure the problem. APDL worked fine once I disconnected the monitor. SMH it was this simple.
