Fluent calculate function compute_force_and_moment in parallel calculation
Hey,
I can't find good documentation for the compute_force_and_moment function for fluent udf. At the moment I am running a calculation in parallel, and i would like to know if i have to sum up the forces calculated from this function ?
Normally you would use the function PRF_GRSUM1() for example if you calculate values in parallel.
Is it needed for this function ?
