Wasif
No it does not work. And to add to my statement above, I'm running these APDL commands in the solution section.
As far as I know, the reason why they are not being stored is because they are midside nodes. I have SOLID90 or SOLID87 in model. These models plot nodal values only at the corner. Most probably ANSYS takes an average of the corner nodal values when I try to export the result. This is something ANSYS probably does itself. However, when I try to get those values from APDL commands, they are not stored since they are not explicitly calculated.
What do you think?
