DrAmine
You are using an old way to crate monitor. Adjust your TUI command first to the new report definitions commands and try again. Maybe at the end you need to concatenate the files outside of Fluent.
I guess it is better if you use UDF to create the report definition here if you are beginner and you do not have experience with Scheme scripting.
