DrAmine
Then probably the surface was not really sharp which is also helpful (interfacial area distributed over a couple of cells). The guideline is a as general guideline based on experiences dealing with the line techniques scheme. I also used that scheme and that was helpful in my case.
Is you result published? I would like to have that reference for internal purpose (the curve you are attaching).
