tomdillon97
You'll need a finite thickness to start with: you can't change the topology with moving mesh.
Hi rwoolhou,
to follow up on this, I am using VCCT and an FSI in ansys. My fluid + solid geometry are as follows.
I have a small initial crack as above. Will I see the FSI grow if I remeshing is used once delamination begins (at the critical G1 value)?
Many thanks
Tom
