Keyur Kanade
Usually, use right click on the error message at the bottom and select show problematic area. It will show some location. You will need to modify geometry at that location or change mesh sizes.
Other option is as follows.
There are many components. I recommend, first reduce your problem size. With so many components, it will be difficult to identify the problem. Only take few components and check if you can get the mesh. Then add some more components and check if you can mesh. By this way you can find out which body is giving problem in meshing.
As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
Keyur
