karthikeyan506
You cant do continuous degradation due to corrosion. You can try to work on APDL but while doing it in APDL you have to write codes for the materials corrosion and exact time or predicted time at which the material will corrode. You can t also take any impact on geometry as ANSYS is a Geo dependent software,
