Aniket
It should be possible as this must have a JScript call to call this pane in front, but as I've mentioned before, these calls are neither documented nor supported, hence I won't be able to help much. I believe you will have to dig it yourself from the JScript files. I believe the following blogs might be some help in the process:
https://www.padtinc.com/blog/ansys-mechanical-scripting-howto-part-1/
https://www.padtinc.com/blog/ansys-mechanical-scripting-howto-part-2/
http://www.padtinc.com/blog/ansys-mechanical-scripting-howto-part-3/
http://www.padtinc.com/blog/ansys-mechanical-scripting-howto-part-4/
