Erik Kostson
You need to define more design points (DP) - there is only one. Not sure why you have 3 E - mod., parameters namely P6-P8?
In any case you need to run more DP - add them below DP 0 - so you should get DP 1, DP2 and so on depending on how many you need.
See here for more help also: https://studentcommunity.ansys.com/thread/parameterize-ansys-mechanical-material-assignments/
