Gijoys4v
Now I come across another issue, I tried with different element size and I also changed the load step with the lowest possible (i gave 0.5mm displacement in 5 steps with minimum 100 substeps in each 0.1mm displacement) for the above mentioned error in another model. How can I rectify the issue. I only changed the width of the solved model say from 10mm to 10.1mm
