DrAmine
Method is okay. If you know which quantity is important for your case better to use it as residual velocity. But you are the only one to know that as I assume you did not start simulating without an aim.
I usually look into Nusselt numbers Heat transfer coefficients swirl number pressure drop wall shear, holdups, smd,and,....
