Ansys Learning Forum Forums Discuss Simulation General Mechanical Why *.rst file and APDL exported file shows different results from manually exported *.txt results? Reply To: Why *.rst file and APDL exported file shows different results from manually exported *.txt results?
Aniket
Have you checked the source code of the Multi Export object extension? I think you should be able to modify it to suit your needs in python and build your own extension. Also if the answer helps please mark it as a solution.
-Aniket
