Wenlong
Hi jmperido1,
Line bodies won't be included in Mechanical. They need to be defined as beams in SpaceClaim to be available in Mechanical (But I guess that's not what you are trying to simulate)
If you want to create some cuts on the surface, maybe you can try either split the surface or create a small gap at the lines.
Wenlong
