Kalyan Goparaju
You can create a custom field function of your equation using the v and w components of velocity, and cell surface area (in the Adaption category). Once the variable is created, you can use the surface integration from Results → Reports → Surface Integrals -> Edit to sum up the custom variable and get the induced drag.
Thanks,
Kalyan
