Keyur Kanade
make sure that you have a solid for subtraction.
if you have solid, please check if it has any errors. you can check it by selecting in structure tree --> right click --> check geometry.
Also you can try creating a enclosure manually and then use 'Combine' command for subtraction.
Keyur
