Keyur Kanade
you converted facets to solid and then extruded to get more solid bodies. now as the converted solid may not have correct definition, it may fail in extrusion and also may have geometry errors in extrusion. It may face issues in connecting these two solids as well.
So best way is to create solid from facets with the skin tool and then proceed.
Keyur
