March 11, 2020 at 9:22 am
Forum Moderator
As the error message states, you need 84 GB RAM to solve this problem.
You can either:
- reduce the node count in the mesh using larger mesh size
- Increase virtual memory of your machine
- switch to iterative solver. For this your RAM requirements will be reduced and HDD requirement will increase, also it will be slower than the direct solver that you are trying to user right now.
-Aniket
