HuiLiu
Hi Kevin1704,
Did you "load" the ACT from workbench page? After load it, you should be able to see the additional tool bars in Mechanical, or you can right click from the tree and insert the additional model settings. The piezoelectric material properties are defined in the "Piezoelectric body", which is from the ACT tool bar.
