Keyur Kanade
For those zig zag elements, you will have slice the body at different locations. Then you will have to use same edge sizing for parallel edges.
For some regions, nodes do not look like connected. You have to use share topology in DM or SpaceClaim. Also you need to have a single part for the bodies, you want to have conformal mesh.
Keyur
