March 12, 2020 at 5:02 am
Thanks for replying.
I found that after assigning "Concrete" in engineering material to the concrete bodies instead of the default "Structural steel", the Total Deformation I get becomes accurate. Meanwhile, the reinforcements are still assigned with the default "Structural steel". So, it seems that the problem is solved.
Thanks again.
