HCR_student
Apologies because I am still relatively new to using this software.
My analysis is about the window frame, where the one outer face is exposed to the outdoor environment at 36.4 degree celsius and another is exposed to the indoor environment at 25 degree celsius. Those temperature settings at applied under free stream temperature with the respective wall thickness. Convection setting is applied to both faces with (outside environment) free convection to air at 36.4 degrees C (5 W/m^2-K), and (indoor environment) forced convection at low speed of airflow over the surface (10 W/m^2-K) at 25 degree Celsius.
Can I confirm that it means if the objective of my analysis was just to study the heat transfer through a body, I would not need to bother about the heat generation rate?
