Keyur Kanade
As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
Yes, please check your boundary conditions.
Specifically check inlet and outlet boundary condition.
Also from images, mesh looks ok. But still check orthogonal quality. The min ortho quality should be above 0.1.
Depending on your inlet conditions, your mesh may need more refinement. Please check the turbulence model you are using.
Keyur
