Rerun your model with double the number of elements through the thickness to see if that changes the result. If it does double it again. This is called a Mesh Refinement Study.
A screen snapshot of a spreadsheet would help with setup data such as Exp. Sample Length, Mod. Sample Length
and columns such as:
Exp. Disp., Exp. Strain, Exp. Force, Model Disp. Model Strain, Model Force
Next, assemble a list of all the parameters that have a range of uncertainty.
  • Length
  • Width
  • Layer 1 Thickness
  • Layer 2 Thickness
  • Layer 3 Thickness
  • Layer 4 Thickness
  • Layer 1 Modulus
  • Layer 2 Modulus
  • Layer 3 Modulus
  • Layer 4 Modulus
  • Layer 1 CTE
  • Layer 2 CTE
  • Layer 3 CTE
  • Layer 4 CTE
  • Delta T for Layer 1
  • Delta T for Layer 2
  • Delta T for Layer 3
  • Delta T for Layer 4
Assign a range for each uncertainty, then assign the worst case for each parameter that will push the Force higher or lower and label those values F+ and F-.  Run a model with all the parameters at F+ and run another model with all the parameters at F- and show the possible variation in the model caused by variations in the input to the model.  See if your experimental result falls between the F+ and the F- curves.
