Han-yu
Hi:
I tried the setting you suggested but still shows error during simulation and give me a different result.
The solve.out message shows as below.
Could you help me take a look?
Thank you
Element 47329 (type = 4, SOLID187) (and maybe other elements) has
 become highly distorted.  Excessive distortion of elements is usually
 a symptom indicating the need for corrective action elsewhere.  Try
 incrementing the load more slowly (increase the number of substeps or
 decrease the time step size).  You may need to improve your mesh to
 obtain elements with better aspect ratios.  Also consider the behavior
 of materials, contact pairs, and/or constraint equations.  If this
 message appears in the first iteration of first substep, be sure to
 perform element shape checking.
